Old 02-20-2007, 12:03 PM   #4
boxster
Originally Posted by tholyoak
Well I assume your 'performance module' is simply going to modify the voltage from the intake temp sensor, tricking the DME into thinking the air is cooler (more dense) than it is, and increasing the injector pulse to richen the mixture. IMHO, the only thing this performance module will do is give you a check engine light.
To answer your question:
You don't say what year the car is but on a '99 the wires are:
1) Temperature sensor (bl/gr)
2) Supply voltage (re/bl)
3) ground (br/wt)
4) 5V reference voltage (re/vi)
5) Signal voltage (wh/bl)
Todd
thanks for the info.
i checked with the company before purchasing the module, but they assured me the on board computer would not give me any errors, ill just have to check and see!! the module has a positive 12 v wire, a negative ground wire, and a wire that needs to be connected to the IAT sensor wire. the car is a 1999 model. so you think the wire is the first one?
boxster is offline   Reply With Quote
