Old 02-20-2007, 10:38 AM   #1
porsche986spyder
Best way to check oil level???
I was just wondering why Porsche decided to use two ways to measure the oil consumption? I mean it's really cool to be able to visually see it as a meter on your instrument cluster, but how accurate is that compared to the old fashion way of using the dip stick? So is the instrument oil check level just to watch it, so you can top it off if needed? Mine always says full. I check the dip stick level every 3k. It says the same. Right where it should be, but I wonder when pulling it out how much of it actually comes in contact with the inside tubing when you pull it out. I always clean it off and then put it back in 2-3 times to get a good reading, but it still seems like it is imposible not to touch the inside of the tubing collecting more oil every time you take it out. Any one else feel this way? Whats the best and most accurate way to check your oil level?
porsche986spyder is offline   Reply With Quote
