They are probably correct. The new 050A Pole Position 285 is 11.4 inches wide at the cross section with a 11.3" tread. These would need a 15MM spacer to fit the inside -- a 33MM offset for your wheels -- would this put the outside of the tire into the fender?
If it were me - I'd go back to them and ask for the 285 and the correct spacer to fit!
We run 285/30/18 KUMHO V710's that are 11.1" cross section with 42MM offset -- wheels are 65MM offset with 23MM spacers -- on 02S w/H&R springs -2 degrees camber.
Good luck,
Ed
