Old 02-19-2007, 01:57 PM   #5
boxster
Originally Posted by idheaton
Over the weekend i was at my mechanics shop and he had a 99 996 in that wasn't running correctly under load.
After hooking up the obd scanner to it he found out that the engine was misfiring on 2 cylinders. His diagnosis is that a cam adjuster was bad so the engine was severely out of tune which was causing the misfires.
Whether or not this applies to your situation or a boxster for that matter, a misfiring cylinder is a severe issue and i hope you are not driving the car anymore until it's fixed.
the obd is just saying that its misfiring on 3 cylinders when idle, its not giving any diagnosis. now theyre gonna check the catalytic converters.
at the moment im still using it yes, you think i shouldnt?
boxster is offline   Reply With Quote
