Old 02-16-2007, 02:06 PM   #6
boggtown
Guest
Posts: n/a
Are you gonna do the pads at the same time? If not it isnt the best... Odds are your pads will have grooves in them and will need to be replaced in a while anyway. The grooves could either wear away your new rotors prematurely and groove them or give you sub optimal braking until the pads wear down flat again. Depending on how aggresive the pad is, how hard the rotor is, ect...
Im gonna get new pads, rotors, hardware, and stainless steel brake lines when I do my brakes in however long it takes to run the front pads down to a "need to be replaced" thickness. And will flush the brake lines and put new fluid in there. Might as well only mess with it once. I am probably going to buy those same rotors, but with porterfield pads. I will of course paint the hat... Gold. And re paint my calipers green. Gold for the honey, green for the money imp smiley guy:
