Old 08-24-2004, 09:55 AM   #5
Jeannot
Jeannot's Avatar
Originally posted by Ad Sach
Probably the easiest way to tell is too remove one of the sway bar mounting brackets (2 bolts in the rear) and pull off the rubber bushing. The part number stamped on the rubber bushing will match up to a specific size sway bar - which will indicate which version of suspension the sway bar is from. This is a 10 minute job that would give partial proof.
Ok, so I guess removing a wheel won't be enough. I'll try that. Thanks !
Jeannot is offline   Reply With Quote
