Originally Posted by FrayAdjacent
Could it be that the belt is just not fully on one of the 'ribbed' pulleys? You see how some of the pulleys have grooves in them that the grooved side of the belt goes into? Maybe if one of those is not on correctly, it's causing the belt to misalign on one of the other pulleys?
Just a SWAG. The way that looks, I'm not sure I'd want to have to replace the belt.
That's usually what causes the belt to come off. It's usually #6 or #5 in the diagram since they are behind the walls and harder to see. Check them closely (with a dental mirror if you have one) or slide your hand down under the pulleys to make sure the belt is completely on.
