It was the switch
Just a follow up on this issue.
I had an independent Porsche tech check out this problem -- he confirmed what the dealer said -- the tranny switch does need to be replaced. I don't know if this is a common malfunction (probably not since the dealer does not keep this item in stock).
I'm having the independent shop do the work since he's about $200 less than the dealer.
-gene
