Thanks for your response
I just drained it from the bottom thru the drain plug, not big deal.
My concern is really if the engine is damaged or just needs an oil separator because it smokes like hell at startup but just for few seconds then stops. Misfires a little bit, I have a CEL (P0300 thru 6) every often. I just erase the last one 2 days ago. I also put some mistery oil in the gas tank to clean the fuel injectors, it sounds smoother now but smokes at start.
