Old 02-09-2007, 06:47 PM   #10
donv
donv's Avatar
Great idea by the OP, much easier than the big plate approach. One note for folks that plan to follow this route: steel + aluminum = galvanic couple... the aluminum is most likely going to corrode at the contact point with the steel clamp. A piece of thick lexan substituted for the aluminum would likely provide the same mounting strength but no corrosion risk.
2001 Lapis/Black/Black, PSM, Rear Speaker Kit, Optima...
donv is offline   Reply With Quote
