Originally Posted by blue2000s
This way the battery isn't raised 3/8" as it would have to be with an adapter tray. It sits at the same height as the stock battery.
Unfortunately, they don't make a reversed pole yellow top so a + cable extension would be required.
Can't you just flip the battery around so that it faces the other way? So your pos. & neg. are on the correct side?
