Originally Posted by djomlas
alrite then, write up it is.
its an EVO intake, or PowerFlow intake, whichever one u like, they aret he same exact thing
i am expecting over 70hp outta this so watch out
They are NOT the same. The EVO High Flow intake kit comes with it's own air box, the TrueFlow, which is what I have does not require the romoval of the stock air box like the EVO ones does. The TrueFlow just uses a drop-in filter that uses the exsisting stock airbox, but does replace the stock tube/snorkle. The TrueFlow is much easier to install. The EVO is probably better, but requires you to remove allot of crap that is in the way (like the intake manifold) and without a mechanical malual it would not be easy. The EVO also has its own housing for the mass-air flow sensor. The TrueFlow uses the stock airbox, so you don't even have to touch the sensor. Just thought you should know. :dance:
