Originally Posted by ukchris
I hadn't fixed the dip switches when I took the pic, although it seems to work both ways, I guess there are some obscure functions that vary.
I added the CD Changer in position 2 but then when I reviewed it it shows in postion 1, I suspect it displays them in the order they are on the loop or something. I had the Amp in position 1 and added the CD Changer in position 2.
When you had the Dension in the loop did the head unit still operate (even though the Dension didn't)?
In the PCM DIP configuration, the head unit would come up, but the Bose amp wasn't recognized on the loop -- hence no sound or Bose menus on the head unit.
In the CDR24 DIP configuration the head unit would just hang on 'PORSCHE' and not come up at all.
On both configurations, if I bypassed the Gateway, the both the head unit and the amp worked fine.
