Old 02-04-2007, 11:02 AM   #11
laphil
Originally Posted by ukchris
Phil - have you had the MOST configuration updated to tell it there's a CD changer?
Yes. I went to the dealership and they set the head unit to enable the CD changer. Position 1 was the Bose (factory), position 2 was the CD changer (the next available open position added by dealer.) An interesting point on your PDF is the positioning in the head unit. Does it matter if the CD changer is first or does it have to be CD changer, then BOSE?
Also, I noticed the DIP setting in your PDF shows for PCM configuration. The original manual is correct for PCM. On the CDR23/24 it needs DIPS 1-3 off, and DIP 4 on, as you stated.
And thanks, the PDF is helpful, but unfortunately I gave up and sent the unit back. I'm waiting for the group buy to happen and some other CDR24 (not the CDR23) non-CD Changer with BOSE folks to take a stab... I'm down about $350+ on this experiment. :ah:
laphil is offline   Reply With Quote
