Originally Posted by dbth
It was garbled on my Mac , I see the text on my Windows PC (different room).
Why would a PDF document not be clear on a MAC , I have viewed many PDF files on my MAC.
I have a 987 with PCM , if I do this , I will have the install and ipod in the front trunk.
Any suggestion?
Thanks.
I created the PDF with CutePDF rather than Adobe, maybe that's why. I'll try the full Acrobat if I get chance.
I don't think you *have* to install it in the trunk but with PCM you can if you want to as you get a much better display for navigating the tracks and so on. If you install in the trunk you can use the same connection method but hook in at the Amp or CD Changer (if you have one). You'll need to find a constant 12v supply, I wouldn't run straight to the battery (especially without a fuse). I read that there is a 12v constant to the audio components in the trunk so you should be able to tap in there or run through the firewall to the fuse box.
