Thread: convertable top
Old 08-18-2004, 08:49 AM   #17
Ronzi
Ronzi's Avatar
One other thing to look for is the key for the wheel locks, if any. I thought mine was missing, but finally found it in the pocket of the spare tire cover.
Also, check the sticker on the underside of the front luggage compartment lid. There may be two hand written sequences of letters/numbers. If so, one of them is the radio/CD code, which you will undoubtedly not have if all of the original doc is missing. The other one is another security code, but I forget what. Maybe the alarm system? Both of these are needed to get everything working again if you ever have to disconnect the battery. Apparently scribbling these codes on that sticker is a semi-standard procedure amongst Porsche dealers, probably in order to save their techs a lot of time when servicing the car. Sounds sort of like writing you password on a stickey and pasting it to your monitor, doesn't it?
Ronzi is offline   Reply With Quote
