Thread: CV Boot
Old 02-02-2007, 10:33 AM   #3
JackG
You have two options to get to the CV boot...
1. Pull it using the factory method which requires a special tool to dissasemble the rear suspension enough to be able to swing the rear wheel hub and carrier out of the way. Then you use a wheel hub puller to press the axle out, unbolt it from the differential, and it's out.
2. Do it the way I described in Replacing CV Joint Boots
You should definitely consider doing all four while you are at it.
Jack
2000 Boxster S - gone -
2006 Audi A6 Quattro 3.2
JackG is offline   Reply With Quote
