Thread: CV Boot
Old 02-02-2007, 07:06 AM   #2
MNBoxster
Hi,
Not impossible, but not easy either. You have to disassemble the wheel hub using a slide hammer to get it out. Then remove the outer CV joint so that the bellows will slide off the driveshaft. Consider changing them all at once, especially if you're DIYing it. Several special pliers are also need, circlip, etc.
Many here have done it. It's more tedious than anything with most of the work involving exposing the bellows for removal/installation. Hope this helps...
Happy Motoring!... Jim'99
