			for those of you that have an air compressor...
i'm not sure about how it cost but my mechanic has this tool that you screw in place of the coolant cap and  use the air compressor to pressurize the system....
after its all pressurized you open a valve and the coolant is flushed out thru an attached hose ....
filling it up was just as easy....all the air was sucked out of the system...a hose was put into the coolant and the valve opened and all the coolant was sucked right into the system...pretty cool i thought...
my mechanic sd this was the best (and easiest) way to make sure that the system was totally flushed or filled correctly.
				- ian
