Old 01-28-2007, 02:31 PM   #12
John V
dj,
How did you ensure that you got all the old coolant out of the system? Since the radiators are all the way at the front of the car and you had the rear end on ramps, it seems to me that there would still be old coolant in the system. In the past, I've disconnected a heater hose and fed the system with a garden hose while the motor was running to flush everything out but it looks like you didn't do that.
Probably not a huge deal - I was just wondering if you left out a step or if you really did just drain and refill.
I would also add - make sure the car is warmed up fully when you drain the coolant. When you refill, make sure the heater is set to full hot. If the heater valve is not open, you won't get out any air trapped in the heater core.
Thanks for the writeup.
JV
John V is offline   Reply With Quote
