Old 01-27-2007, 12:44 PM   #12
MNBoxster
Originally Posted by djomlas
well depending on the temperature, on the bottle it said if you will have your car in up to -34 degree temeratures mix 50/50 coolant and distilled water, which is what i did.
if you will be in even colder cinditions it will show different mixture conbinations.
so you need certain capacity, now whichever way yo want to mix up your coolant/distilled water mixture is up to you, or better said the conditions you live in.
hope this helps
Hi,
A couple of things. Water is the best heat conductor available, so the more water you have the better for this purpose alone.
But, the Coolant also provides corrosion and lubrication protection, so you need a certain amount of this in the mix as well. 50/50 (distilled water/Coolant) works fine, but 60/40 is better for heat management while still providing adequate corrosion and lubrication protection.
So, check the Coolant and use the smallest concentration of Coolant to distilled water your area's avg. temps call for. Hope this helps...
Happy Motoring!... Jim'99
