Originally Posted by djomlas
turn the car on, and let the engine get to the operating temerature, and every minute or so rev it up to about 4200RPM, this will take about 10 minutes or so.
shut engine off, let cool off, then top off to MAX again, put the bleeder valve down, replace the plastic cover, tighten both caps on.
some people like to drive w bleeder valve open for a day or 2, this will not hurt the car
Just a couple of questions as I'm gonna do the coolant system flush soon. In the Bentley manual it says the car has a coolant holding capacity of 4.5 gallons,now that's 100% coolant right? Now as I let the car idle and the coolant needs to be filled the mixture that you put in at that time should be 50/50 coolant/distilled right?
Is this the right coolant?
http://www.partsamerica.com/ProductDetail.aspx?categorycode=3219&mfrcode=HAV&mfrpartnumber=7994
-99' Zenith Blue 5-spd...didn't agree with a center divider on the freeway
-01' S Orient Red Metallic 6-spd...money pit...sold to buy a house
