Old 08-15-2004, 08:05 PM   #23
Adam
Originally posted by jefla
No modifications to shift linkage, etc. The car shifts fine; I think the problem is the operator. I'm letting the revs drop too much before engaging the clutch.
Letting the revs drop? Do you mean your are letting the engine chug at low rpm before shifting to a lower gear? It says in the manual you can damage the engine if you let the engine lug along at less than 1,500 rpm.
Adam is offline   Reply With Quote
