Old 01-26-2007, 03:38 PM   #1
CJ_Boxster
Send a message via MSN to CJ_Boxster
Try doing this, talk to a non-dealer porsche mechanic and tell them that you had the dealer repair a leak in the trasmission, Say that it was a leak around a hose or sensor and that the dealer wants you to pay again for them to fix what they didnt fix, This will atleast trick the mechanic into thinking you already know what the issue is and wont assume you need a replacement, That way they will try to source the leak FIRST before diagnosing it as a totally bad transmission.
If you just took it to them and said the tranny is bad cause dealer said so, they will likely not try to find the leak.
--Proud Boxster Owner/Tech,
Carlos J Cazares
FastForward Performance
http://i10.photobucket.com/albums/a1...er/newsig1.jpg
CJ_Boxster is offline   Reply With Quote
