Originally Posted by ntroffroad
I have a 99 Boxster and when it first starts up (cold) all is fine, but when it warms up, transmission fluid literally sprays from what appears to be the top of the trans. I havent had a chance to check it out yet, but being a sealed trans, is there anything specific that could be causing this? I find it hard to believe that at only 60k miles it would have trans failure. The dealer has done all the scheduled maintenance including a fluid and gasket change but not filter on the trans just 2 months ago.
Any info would be helpful, thanks.
That's normal. You should be OK.
