Originally Posted by Bavarian Motorist
Are the bars on 987s roll bars? My dealer said so, but I know he's full of **************** (told me 800 miles for break-in)
They aren't metal or anything so I'm not sure.
I want to run a hpde event with nasa. Thanks
Oh yeah, how do I access my engine ????
Hi,
Yes, the Roll Bars are made of high strength steel as is the windshield header and 'A' Pillars. These have sufficient strength to support the car's weight.
However, you could also be subject to the
Broomstick Rule for Track, DE, and Auto-X events depending upon their requirements and your height when seated.
The Broomstick Rule states:
Open cars must be equipped with an approved
roll bar. If the car is equipped with factory seat belts, a broom stick placed across
the top of the roll bar and the front roll hoop/ windshield frame shall be at least 2” above the driver’s helmet. If the car is equipped with current SFI approved legal 4, 5 or 6 point harness system the drivers helmet shall be at least below the level of the broomstick.
If you cannot pass this requirement, a Roll Bar Extension may be required, see:
http://www.northstarmotorsports.com/products/sfID1/34/sfID2/35/manufacturerID/91/productID/1479 and
http://www.bombaydigital.com/boxster/projects/bkrollbar/ Hope this helps...
Happy Motoring!... Jim'99
