Originally Posted by djomlas
when i had my cap problem, i flushed mine w the yellow bottle Prestone, said for all cars and all models.
and it was like 274359832758374 times cheaper than porsche coolant.
no problems with it
Hi,
That was probably not the best thing. The coolant you describe contains silicates and these can form a gel reducing/blocking Coolant Flow, this problem has come up on several Boxsters.
In addition, this type of Coolant insulates the metal of the engine (read below) and causes a reduced heat transfer (not a good thing on an alloy engine). If it were me, I'd drain it and flush it ASAP and use the proper Extended-Life Coolant...
Happy Motoring!... Jim'99
