Thread: radar detectors
Old 01-15-2007, 03:15 PM   #10
mwh98
Self Installed SR7
Originally Posted by jci-joe
I see there are a number of radar detectors with remote mounted sensors including the Passport SR7+ and the Calibre K40. Has anyone installed one of these in a Boxster and what is your opinion. Also, if you installed the SR7+, do you know if the laser shifting has worked? At $1,599, it seems pricey unless it truely works.
Since I have not seen too many comments on these, my assumption is that they are not widely used.
I think they are so few and far between is the price, there is a lot more you can do for $1,600.00+. I found a new SR7 +shifters on fleabay ($650.00) and did the install myself. It was probabley the toughest install I have ever done., considering you are running wires from bumber to bumber.
I have had no experience with V1's but have an 8500 and an 8500 X50. The X50 was a noticible improvement from the regular 8500, while the SR7 is and the X50 are very close.
I have a picture of the install, but the server is limiting the file size, so I can't upload it. I cut out the bezel rectangle in the bow tie under the HVAC in the center console. For a while the Escort site has a custom instal in a Boxster.
After it was all done, I'm extreemly happy with the look and performance of the SR7. The only change is to add the optional external speaker for when the top is down, so you can hear it, since it is a little out of your line of sight.
Mark
2001 Seal Grey 986
San Antonio, Texas
mwh98 is offline   Reply With Quote
