			you can do it in a few hours, my whole process took about 2-3 hours. i did paint the calipers before i received the decals (some mixup). so then when they did show up it was a matter of taking the wheel off and putting a decal on.just make sure you take ur time cleaning them, if they are not clean paint will not stick good, thats the key here.
 the way tht i did my caliers was lift up the front end, take wheel off, clean and paint one coat, then move on to the other side and do the same, then i went back and did the 2nd coat on 1st wheel, waited a few mins for the other side to dry and put a 2nd coat on that side, put the wheels and and repeated the process for the rear calipers.
 and yes, you can put the wheels back one the car while the calipers are still 'wet', just make sure you dont touch them with the wheel or somethign else.
 i did mine with the caliper paint kit from Murrays (also at autozone) and i tought at first that it wont be enough, but i did 5 cars so far, 2 coats per caliper per car, and still have majority of paint left. it somes with a calipers cleaner spray, and brush and instructions. i got a diff brush couse that was a cheap one to be honest.
 paint held up good on all cars, no chips yet either, and if there is to be any chips its easy to touch it up if you got a brush on method going, couse u can just touch up the chip versus masking off the whole caliper and go trough the whole prcedure again.
 also, i didnt mask off anythign pretty much, no drips or spills for me, so
 good luck
				__________________http://i34.tinypic.com/157yslk.jpg
"I couldn't find the sports car of my dreams, so I built it myself." ~F. Porsche
Gemballa springs::litronics::Eurotech 18s(275/225)::B&M::MOMO wheel:: exhaust cutouts::EVOcoldair intake::OEM smoked tails & sidemarkers::
colormatched bumperettes::Top Speed Pro-1 exhaust::
my cardomain/pictures page
