Old 01-10-2007, 07:57 AM   #6
MNBoxster
Originally Posted by clb0099
well,
The mechanic i just got the car back from told m he believed it was the switch . So it wasn't like i came up with the idea. I see he multimeter tool ur talking about on ebay any particular one you suggest since there is some many of them .
Hi,
Well, without testing the circuits, even your mechanic is guessing. If he turns out to be right, then it's just blind luck. And, afterall, he's spending your money - he can afford to be wrong.
So far as a multimeter, it all depends upon how much you think you'll use it. They can range from $9.99 to $175 or more. I personally believe in investing in good tools. Over the past 25 yrs. I have acquired more tools than many mechanics. But, they are all used and very good quality tools, bad tools make a job more difficult.
Whatever, you only want a Digital Multimeter. Many of today's circuits in cars use very small voltages. An Analog meter can actually damage them.
Fluke is probably the best brand out there and the one I mainly use, they have many models to choose from, some specifically for automotive applications: http://us.fluke.com/usen/products/categorydmm
The best features to have are: Continuity Testing, AC, DC testing, Resistance (Ohms) Testing and some even have a Temperature Probe. Also, get one with a Rubber jacket so it can take a few knocks and not be damaged.
There are over 700 on eBay right now and there are many different types and costs. A couple are: http://cgi.ebay.com/Digital-MultiTesters-DT-830B-Multimeter-Hand-Tool-Meter_W0QQitemZ300067982991QQihZ020QQcategoryZ5253 4QQrdZ1QQcmdZViewItem and http://cgi.ebay.com/Digital-Multimeter-DMM-with-Capacitance-Transistor-Temp_W0QQitemZ140070852029QQihZ004QQcategoryZ50964 QQrdZ1QQcmdZViewItem . The 2nd one is the better of the two, but shop around, I didn't check all the eBay listings.
Once you have one and learn to use it, you'll be amazed at all the uses you find for it, and you'll be starting to build a proper set of tools.
Here's a good primer on how to use a Multimeter: http://www.multimeterwarehouse.com/usingamultimeter.htm . Hope this helps...
Happy Motoring!... Jim'99
