Old 01-10-2007, 08:49 AM   #1
Ray
Unhappy Tail Foglight Problem
Background:
99' 986 17k miles, 2nd owner.
Problem:
I noticed my right rear tail foglight was not working. I opened the light bay and discovered there was no bulb. I put in a new bulb, still no light. If you look at the light chasis you will notice that the circuits are exposed so I tested for voltage across where the rear fog lamp is ... no go. I then followed the curcuit to the brown wire and gray/white on the plug and again tested for voltage ... again no go. The other lights all work. Where to look next???
And yes, the fog lights were on
Ray is offline   Reply With Quote
