I'd definitely be thinking either the MAF, or maybe an 02 sensor... the mixture is not getting there correctly.
You should be able to just disconnect the electrical connection to the MAF, which will put the engine in a default/safe fuel/air map. If it runs better with the MAF disconnected, it's likely a bad MAF. If it doesn't change... might want to have a shop check the computer to see if any of the 02 sensors are giving bad readings or something.
otherwise, it could be a fuel system problem... or maybe an ignition problem?
