Interesting, you described a popping sound. Have you done anything else to the car lately? When I had a popping sound it was due to a vacuum leak. Its a big long boring story but it ended up being a broken oil tube. I tought my maf was bad too and as it turns out it probably wasnt. Does your car have a rough idle? When the car is cold it takes readings from the maf until the 02's heat up. The car switches back and forth between 02's and maf. Another question, do you get a check engine light? If so another board member turned me on to running the car to Autozone and getting them to tell me the code for free. I bought a code reader on e-bay since then so I can read my own codes now.
2002 TT
