Old 01-09-2007, 01:03 AM   #2
huzzah !
The anniversary model used a 5mm spacer I believe. Which is subtle but does give you a lil' something.
Combine that with a slight bump in tire width where it needs it. I'd go for the 225 45 up front, stick with the 255 out back. And maybe fit some of the shorter ROW springs to lower your stance and you should get that more aggressive look you want without too much compromise.
And then of course you should driver faster. That's the best way to get that more aggressive look, with more aggressive action.
jh
huzzah ! is offline   Reply With Quote
