Originally Posted by Houston C4S
Theses mufflers are not, let me repeat that, not the same.
You can look right through the '04, end to end (off the car,
of course). If you put a lens in it you could use it as a telescope
(albeit a rather heavy and bulky one).
You cannot do that with the non-S '01.
- Mark
That's weird. On my 01 base, I pulled my OEM muffler before installing my Dansk pressed sport exhaust, and the OEM unit was exactly as you described the 04 muffler - ie. that you could look right thru it from one side to the other. With my Dansk, I noticed that you couldn't do that, as it had tapering tubes with holes in it that formed a cone.
I do think the 04 muffler does sound different from the 01 though, as it was engineered to produce a more raspy growl than the earlier models, but still not loud. As for flow characteristics, I have no clue. I just like the sound of my Dansk better than my OEM one.
