Old 01-03-2007, 08:06 PM   #3
MNBoxster
Originally Posted by AUDIOGUY
I can almost guarantee the codes are due to the intake. I have been getting them off and on for the last year. My question to Jim is will the car be affected long-term by the cel being on for the 1128 and 1130 air fuel mix issue or not. I feel that my car is running very well with the Evo intake I have either with or without the CEL on. Also, it goes out every once in a while for about 2 weeks or so and then reappears. I thougt of buying a new MAF but if it will ultimately be fouled, maybe not.
Any further suggestions.
Thanks!
Hi,
It's possible you are having trouble now and not know it. The DME may be selecting the improper Map and operating parameters, though it may seem fine to you. Longterm effects could be shorter lived emissions system and so forth.
The other issue is that these codes can mean something else entirely. There is no specific Bad MAF code, only codes such as these two which indicate symptoms leading to the discovery of a failed MAF. Some other conditions or components can throw the same codes, which you would be ignorant of until other codes appeared, or something broke, or performance suffered tremendously before you noticed. By that time, you could have caused some $erious damage, not to mention any ill longterm effects...
Happy Motoring!... Jim'99
