Originally Posted by kls
"Kls, you need new rear tires...soon. When new, our tires are about 10/32's. Tires are considered "worn out" at about the 3/32nd mark."
Thanks bmussatti, it shall be done. Would you match the Michelins on the front, or just get a new set? Also, does the tire pressure sound OK?
Kls, Michelins are great tires...$$$$...but good. I would just replace the rears with a set that matches the fronts. Your tire pressures appear fine.
