Originally Posted by David N.
I actually use nitrogen-filled tires. They're really good! I even have a special 'nitrogen compressor', fills anything with a nitrogen gas mixture. This mixture is good for so many uses...cooling hot things (believe it or not Porsche used to use it directly on their engines, before they switched to dihydrogen monoxide)...running ratchets and dental drills...there are even animals out there that like to breath a nitrogen-rich mixture... If someone's offering to fill your tires with for only $20, it sounds like a real steal
Hmm, perhaps I'm being a little presumptious tho...maybe someone else can provide an opinion?
-David
where did you get the compressor and what type is it?
