Old 12-31-2006, 08:44 AM   #3
MNBoxster
Originally Posted by Allen K. Littlefield
Thanks Jim, I take it the spring tension is what holds the button in place and prying up overcomes this to allow removal? Once the button and spring are out will the knob just slide up and off or are there any other screws of clips to be removed? Diagrams like you sent are the greatest and thanks again.
986geezer
Hi,
The Spring provides the resistance against pushing the Selector Button. The Button is held onto the knob just by a slight compression fit and by a small bracket molded onto it's backside which slips over the little Bar visible in the 2nd image just above the Spring Clip. Remove the Spring Clip shown in the image, and the knob will just lift off the stalk...
Happy Motoring!... Jim'99
