Old 12-30-2006, 02:32 PM   #1
MNBoxster
Originally Posted by Allen K. Littlefield
Has anyone removed a Tiptronic shift knob and if so was it a bear or relativlely easy? Mine has a few scratches and worn spots that I could touch up with a spray can if I could remove the shifter without too much ceremony. Any suggestions?
986geezer
Hi,
The Tip knob is very easy to remove. The best way to do it is to take a small right angle Allen Wrench, insert it under the Selector Button from the bottom. Then you pry the bottom of the Selector Button out of the Shift knob and remove it. Underneath, you'll find a Conical Spring and a Spring Clip. Remove these and the Shift Knob will lift off the stalk. Installation is the reverse, but note the position of the Conical Spring when removing it and reinstall it in the correct orientation. See attached images to visualize the procedure. Hope this helps...
Happy Motoring!... Jim'99
