Old 12-30-2006, 01:17 PM   #5
MNBoxster
Originally Posted by dave986
Thanks for the help guys.Fortunately after leaving the car on for 30 mins I was able to put it in drive.Was it possible that something froze because to the low temparature or is there something I should get checked out??
MNBoxster
No I wasn't able the press down on the shifter.The brakes lights wasn't coming on as I press the brake pedal also.
dave
Hi,
My guess is that you picked up some slush which then froze and prevented the Brake Pedal from releasing the lock-out mechanism. This mechanism prevents the shift selector button from being depressed if the Brake Pedal is not 1st depressed, and this sounds like what had happened to you...
Happy Motoring!... Jim'99
