Old 12-30-2006, 08:28 AM   #3
MNBoxster
Hi,
When you depress the Brake Pedal, can you also depress the Shifter Button? Since the lights are not working, I suspect you have a failed/failing ignition switch and lockout mechanism. Keep trying because it may work sufficiently to get it into drive so you can return home or take it for service. Hope this helps...
Happy Motoring!... Jim'99
