oh sorry, Yes you have the right side on the left and the left on the right.
I performed my own little test on my non-ABS eclipse with a complete set of Brembo slotted/drilled rotors, they definatly worked better with the slots daggering into the air at the tip of the rotors, not fanning out air/heat.
You'll also notice a SLIGHT bit more of grip during normal braking conditions with the rotors installed the correct way.
