Old 12-25-2006, 08:24 PM   #1
kls
I agree with Adam. I bought their starter kit with all the Z's they could think of to confuse you with, and Z2 is the one you want. I do believe that you should follow their program; wash with Dawn and clay the surface before you apply the Z2. You can get the clay anywhere, so no need to buy theirs. They recommend the Z5 for taking out swirls, and it may help, but after a lot of elbow grease, I still have swirls.
They will also recommend ZFX, which appears to simply make the Z2 dry faster. They charge something like $20 for about 27 drops. I found if you put a coat on and wait a few hours, it drys just fine. Also, if you use the ZFX you have to mix it and use whatever you mix. Mix too much and you have expensive garbage.
kls is offline   Reply With Quote
