I'm sure it changed it a little, but nothing that I can tell. It should be no different than when I pull the spare tire out up front for an autocross event. When I put in new seats, that will also reduce weight and change the distribution.
I guess there are many things that can change the weight distribution, but that is fine. If you calculate how much 20-30lbs changes it, it's not much.
-David
