You will enjoy the sound of the motor as it winds up, sounds really good.
It gives me a better feeling for the motor, since I do a lot of diagnoses through sound and then examination.
There are pictorials on the web how to De snorkle.
If you need one let me know.
It is pretty simple as long as you are careful with the little black tabs holding the side scoop in...
Once there [scoop is out of the way] you need to pull the snorkle out, took some force for me. I also used a little WD-40, it is only a press fit.
