Originally Posted by bmussatti
Hey Sammy, I will take you up on this in 2007! When you do the brake fluid, this also does the clutch fluid too...right??
Yes, the clutch uses the same fluid as the brakes and can be done at the same time. I flushed the brake lines only before I put Nicole up for the winter, but I plan to put her up and do the clutch this spring. I was going to do the clutch but I didn't have a stubby wrench at the time so I decided to wait.
