Originally Posted by John V
I can go around a skidpad in steady-state understeer or steady-state oversteer. Does that mean the car oversteers AND understeers?
The point I'm trying to make is that there is a lot more to it than saying "this car understeers" or "this car oversteers." What are you doing when it over/understeers? Braking and turning into a curve? Going through the middle of the curve? Accelerating out of the curve? Going in a bit hot and decelerating / braking IN the curve? It's not as simple as people are making it out to be. With the Boxster (and several other cars I've been lucky enough to drive hard) you have so much control over what the car is doing, it's hard to just label the car as one thing or another.
I'm with you John V in that what you feel on a track is dependent on what you are doing with the car; however, if you are doing a skid pad test correctly you will find one or the other. In every case I have driven a production level car on an actual skid pad I have found understeer.
