Old 12-16-2006, 08:14 PM   #30
dcporsche99
"I have been keeping track of these headers and trying to decide if they are worth it or not. Your input means alot,thanks."
I would have to respond,.... it depends on what you want the headers for. I honestly wanted them because of the following two things: (1) inexpensive and(2) I wanted to know if I could install them myself. Now, if I end up feeling a slight difference in the ride (more power and a nice sound) without throwing any lights,.... well, I'll be happy. :dance: I haven't seen any CEL lights yet, but then again I don't think I let it run long enough to throw one off. Isn't there a time frame for these lights to go off?
"I thought Randall said he zip tied them out of the way? You may want to search for some threads on the header wrap before you install them,it has pros and cons. "
Unless, I quoted him wrong, this (below) was taken from post #15. Maybe I misunderstood him. If you could provide me with some of the pros and cons I would certainly appreciate it. Also, if there's an alternative, then I would appreciate that as well. Thanks in advance.
"Oh yeah, be sure to zip tie off the AC line on the driver's side to move it away from the new header, and then wrap it with high temp foil tape or exhaust wrap to keep it from melting."
"I may need to do this mod sometime in the near future."
In this case, I will try to post more stuff to hopefully help out...although, ...since your car is a more recent model, it may have wonderful little tidbits of its own... I think cats go with your headers, right?
dcporsche99 is offline   Reply With Quote
