Originally Posted by MNBoxster
Hi,
I suspect that the Bushing is Delrin, and not Nylon. It would most likely prove to be more wear-proof than the softer Teflon one over time...
Happy Motoring!... Jim'99
The yellow tint is the giveaway. It's the natural color of nylon. Delrin's white when not colored.
Teflon is typically used for bushing applications like this. It's the perfect application. Although Delrin would also be a good material here as you correctly state that it's wear restance is higher, it's friction coefficient is about 2.5 times that of teflon.
